TBF TBM Avenger 1/48 Italeri terminé !!!
Re: TBF TBM Avenger 1/48 Italeri
Pour vous guider un peu :
Selon Dana Bell : "Bronze Green # 9:
A dark, oily green dating from Nov. 1919. Circa 1938 specified for interiors of enclosed cockpits and seats, passenger compartments.
Nearest FS # 14050 / 14058 with BG #9 being a little darker and glossier.
Available model paint: Being released by White Ensign Models fall of 2007 until then an RLM 70 going toward the black/green shade can be used."
Selon l'IPMS-Stockholm : "Bronze Green:
Like Zinc Chromate, the term Bronze Green is generic and describes a dark green finish obtained using oxidized bronze as a pigment. Still used today, the term is another example of a name designating a chemical composition becoming the name of a colour. Many people associate the word Bronze with red-brown colour, but this is not the case for Bronze Green. The pigment itself contains mostly Copper Carbonate, a compound responsible for the green patina often seen on old Bronze monuments.
Dana Bell was the first to unveil the existence and use of these colours in Air Force Colors, Vol 1 almost twenty years ago. Although it is now generally agreed that Bronze Green was widely used for cockpits, we still cannot claim to have the answers to all the questions about Bronze Green and its successor colour - Dark Dull Green.
Bronze Green was specified as standard for U.S. Army cockpits in the late 1930s, but was also used by the Navy. Grumman and Republic seem to have used Bronze Green extensively, possibly more than other manufacturers. This may be attributed to both companies being located in the Long Island area, subcontracting paints form the same sources.
Bronze Green has been confirmed for the seats of North American P-51 Mustangs - which were probably subcontractor-supplied. Pilots' seats and many of the internal fittings in the Boeing bombers were also painted in this colour.
Bronze Green could have been used also for forward anti-glare panels on silver aircraft. For example, Army maintenance instructions called for its use on B-18s."
Toujours selon l'IPMS-Stockholm : "Grumman TBF/TBM Avenger:
In earlier production models TBF-1 and TBF-1C, the crew compartment was finished in two colours - Bronze Green forward from the bulkhead in front of the turret with Interior Green for the rear crew areas. Grumman Grey was used inside the cowling.
In a later set of Erection & Maintenance manuals, Dull Dark Green replaced the Bronze Green in the cockpit.
The TBM-1C and TBM-3 series aircraft built by the Eastern Aircraft Division of General Motors had everything from the inside of the cowling all the way back painted Interior Green.
In common with the general Navy practice the wheel bays, undercarriage legs, wheel hubs, landing flap bays, etc. were all finished in the lower surface colour throughout the Avenger production."
Un échantillon fourni par Dana Bell :
USAAC interior colors.jpg (25.86 Kio) Vu 1061 fois
Le Bronze Green #9 en haut, le Dull Dark Green au milieu, l'Interior Green en bas.
stradivarius
Message par stradivarius »
Mince, donc le TBM tout vert intérieur ?
Benoît
Message par Benoît »
stradivarius a écrit : sam. 9 déc. 2023 08:31 Mince, donc le TBM tout vert intérieur ?
C'est cohérent ton cockpit, ne touche à rien. 😉
Un petit filtre jaune ne ferait tout de même pas de mal. Là c'est vraiment très bleuté je trouve.
stradivarius
Voilà ça devrait être plus convaincant :
WB auto
WB a 6500 k
La seconde a 6500 k est la plus représentative.
Benoît
Logan a écrit : sam. 9 déc. 2023 10:58 Un petit filtre jaune ne ferait tout de même pas de mal. Là c'est vraiment très bleuté je trouve.
Où nous faire une photo en lumière du jour car la ref de peinture utilisée est normalement la bonne et présente une dominante. 🤔
Benoît
stradivarius a écrit : sam. 9 déc. 2023 11:42 Voilà ça devrait être plus convaincant :
WB auto
WB a 6500 k
Tu m as devancé ! 😁
Ben voilà c'est parfait en fait ! 👍
Ca reste un peu bleuté à mon goût mais c'est clair que c'est beaucoup moins choquant comme ça.
stradivarius
Note pour plus tard : faire gaffe à la balance des blancs.
Benoît
stradivarius a écrit : sam. 9 déc. 2023 11:53 Note pour plus tard : faire gaffe à la balance des blancs.
La base ! 😊
stradivarius
Je me demande les réglages que j'ai pu utiliser auparavant. Je vais vérifier si j'ai pas un coucou rose. :D
Abes
Message par Abes »
Salut. Est ce que tu as déterminé la version?
si c'est un TBF early, tu as raison. ( TBF/TBM Avenger: Bronze Green (Early TBF-1); Dark Dull Green (Late TBF-1/1C); Green Zinc Chromate/Interior Green (All TBM versions))
Issu de ce site franchement très bon.
https://www.theworldwars.net/resources/
Et ça m'intéresse, j'ai un HB à faire,
stradivarius
Je lui fais un schéma atlantic. Sur la notice c'est un TBM 1C mais de 1944. Pas très early.
Abes
Message par Abes »
Si c'est un TBM, c'est donc complètement interior Green.
stradivarius
:-? J'ai collé le cockpit sur une moitié de fuselage. Ça va être compliqué de reprendre
tomcat
Message par tomcat »
Abes a écrit : sam. 9 déc. 2023 18:31 Si c'est un TBM, c'est donc complètement interior Green.
Pour moi c'est le plus beau des camo pour les Avenger, Dauntless, Helldiver et Wildcat. D'ailleurs j'ai une boite de chaque que j'ai bien prévu de faire a ces couleurs. Rdv en 2024
stradivarius
Mon TBM1c va devenir un TBF1c. Juste un changement de manufacturier et hormis la couleur intérieur pas de différence. J’ai vu pas mal de discussion à ce sujet sur irc et britmodeller.
stradivarius
Histoire de ne pas perdre le post dans les limbes, petite avancée avec le bébé en croix et sous couché en noir.
Il ne reste plus qu’à corriger les petites pétouilles et j’attaque le camo Atlantic.
Pourquoi une sous-couche noire ?..
stradivarius
Je voulais tenter une nouvelle technique autre que le pré ombrage des lignes de structure. Et en plus ça me fait une couche d’apprêt pour la solidité.
OK, merci. Pas bête, ça se tente.
Une sous-couche noire, c'est pas facile à recouvrir et ça éteint les couleurs. Moi j'aurais fait une sous-couche blanche mais je suis curieux de voir ce que ça va donner.
iwik
Message par iwik »
Salut!
Juste pour info pour plus tard, tu peux utiliser du IJN green pour le Bronze green.
Ciao
IWik
stradivarius
Logan a écrit : mar. 23 janv. 2024 00:59 Une sous-couche noire, c'est pas facile à recouvrir et ça éteint les couleurs. Moi j'aurais fait une sous-couche blanche mais je suis curieux de voir ce que ça va donner.
J'appréhendais avec les acryliques et surtout du blanc mais pour l'instant j'aime bien. Attention c’est la première couche très fine mais j’hésite même à en faire une seconde.
Du coup je suis assez content de la vallejo air. Je galère pas trop. Maintenant les sessions sont courtes. Les bouchages sont peut-être pour plus tard.
stradivarius
Bon, la sous couche noire n'est pas trop perturbante.
