FOUTUS DECALS TRANSFERT EDUARD
Tourist-51
Re: FOUTUS DECALS TRANSFERT EDUARD
Message par Tourist-51 »
PEYO a écrit : sam. 18 oct. 2025 14:18 Salut,
C’est pourtant ce que je fais…mais cela ne suffit pas :/ .
Voici toute la procédure telle qu'elle fût décrite par un certain Gary C. sur Britmodeller il y a une dizaine d'années (pardon c'est en Angliche):
"The best way to get all Japanese decals ( Fujimi, Hasegawa, Tamiya etc)to work as they're supposed to is use hot water and the correct setting solutions. You'll need a bottle each of Gunze Mr Setter and Mr Softer. Micro sol and others won't work as they're formulated differently. Do not use Gunze on Microscale or Cartograf decals as it will chew right through them.
Dip the decal in hot water, it doesn't need to be boiling but it does need to be fairly hot. The temperature of a drinkable tea will do. The glue is heat activated and is what makes up most of the thickness. If you dip it in cold water you'll spend the rest of the day waiting and cursing.
Lay down some Mr Setter, this is in the blue bottle. It acts as an additional glue. Slide the decal onto it and into postion and leave it alone. The decal should wrinkle a little.
Give it 10 mins or so and go over the decal with a brush with a little Mr Softer (green bottle) on it. Use sparingly as it is extremely hot. Too much and it will damage the paint, especially the weaker acrylics. The decal will now wrinkle a lot. Do not touch it as it is almost liquified at this point.
Once it is dry it will have smoothed out and will lay down beautifully over just about any raised or recessed detail you care to think of. Used properly it is probably the best conforming decal process in the industry. Used incorrectly and you'll be just another guy complaining about crap Japanese decals."
C'est ce que fais depuis que j'ai lu ça et ça fonctionne trés bien.
On peu aussi remplacer Mr.Setter et Mr. Softer par la solution décals de Tamiya "Mark Fit" (qui existe aussi en version Super Strong).
Christian A.
boutdhomme
Message par boutdhomme »
Ces échanges sont très instructif.
J'ai testé chatGPT pour traduire et mettre en forme le texte en anglais:
https://www.dropbox.com/scl/fi/95lcrvyh ... kkanq&dl=0
En voici un pdf avec une description didactique du processus de pose du décalque Japonais :)
Olivier.
PEYO
Message par PEYO »
Merci Olivier pour cette traduction.
J’ai la confirmation que le Mr Setter vert est très agressif et peut attaquer la peinture du décal, mais aussi celle du modele, si utilisé en trop grande quantité.
J’en ai déjà fait les frais, cela me rassure.
Tourist-51
Les solutions a décals Tamiya n'abîment pas la peinture.
Christian A.
boutdhomme a écrit : jeu. 23 oct. 2025 19:06 En voici un pdf avec une description didactique du processus de pose du décalque Japonais :)
Olivier.
Merci olivier :x
PEYO
Message par PEYO »
Tourist-51 a écrit : ven. 24 oct. 2025 04:57 Les solutions a décals Tamiya n'abîment pas la peinture.
Oui mais ils ne sont, à mon avis, pas aussi efficaces…
je constate que le sujet decals, et peu importe la marque, reste insondable pour les maquettistes!
bx19gt
Message par bx19gt »
Il y a quand meme des marques ou les decalques posent peu de probleme
J'ai toujours eu de bon souvenir avec ceux de special hobby.
De meme quand eduard a utilisé les decalques cartograf (ex sur le F-4B)
J'ai aussi utilisé quelques decalques dora wing et là aussi ras
Les anciens Eduard ne m'ont aussi pas posé de pb (Mirage III premiere edition)
Les seuls ou j'ai vraiment des problemes ce sont les recents que je n'aime vraiment pas et qui sont des points noirs alors que le kit est excellent en general
bx19gt a écrit : ven. 24 oct. 2025 14:41 Il y a quand meme des marques ou les decalques posent peu de probleme
Je confirme! on en revient toujours à la même conclusion, Eduard se fourvoie avec ce nouveau type de decals.... gâchant le plaisir de leur kit de grande qualité .
olivdelyon
Message par olivdelyon »
dirtydm a écrit : ven. 24 oct. 2025 15:39
je dirais que les ennuis chez EDUARD ont commencé avec le P51 au 1/48. j'avais pris une royal class....l'horreur....tous partis en miette dans l'eau..
